Old 04-16-2013, 10:26 AM   #10
insite
996 is 3.25" ID, no? and, from what i recall about your install, your maf housing is located right after a bend?
pretty sure the 996 is 3.5".
MAF sensor should be at least 1 and ideally 1.5 pipe diameters from a bend. in this case, that would be 3.50" - 5.25". i am at the upper end of that range.
EDIT: if you look at the 996 MAF housing, the inlet is a funky shape and VERY close to the airbox itself. probably not a comparable measurement environment to the one below.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
