Old 04-09-2013, 12:42 PM   #10
seningen
seningen's Avatar
If the IMS to crank chain wore thru the wear pad of the aluminum tensioning paddle shown on the right side in this pic of a 2000 Box engine crank housing, it will make shavings like that until it breaks in half. If you remove the chain tensioner right beside the oil filter you can get a peak at the paddle & Maybe see if it is damaged. The chain & wear pad are on the backside, so it could be excessively worn, & you can't see it thru the hole. When you remove the oil sump plate you will probably see more shavings there.
This is what I was referring to.
You can fit a boroscope through the hole and inspect it as well. We did this once --
found one of the chains (of two) had broken. We saved the engine - but it still had to be torn down and put back together with a new paddle and chain assembly.
The chain broke because it was wearing a groove in the paddle.
That's a lot of shavings -- and my gut says that you would be down to some material
in the bearings that was ferrous (isn't there copper in most bearings -- I know there is on the 944)
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
