Old 04-04-2013, 11:14 AM   #7
BYprodriver
BYprodriver's Avatar
I am using the 987 Maf tube mounted to the airbox flange with the oem o-ring seal & clips. The flange is what makes it hard to install the airbox past the oil heat exchanger. Once you get the box bolted in you can install the MAF tube. Hard to see in this pic, but the widest clamp to the right is clamping the hose to the MAF tube:
