Old 04-02-2013, 05:41 PM   #1
mikesz
mikesz's Avatar
How to get horn frame off?
Horns were not working, checked fuse, relay, replaced horns. Now horns go off continuously. Tried folded piece of cardboard slipped under top of steering wheel cover didn't work. So I figure the bushings in the frame are shot. I have a 99 boxster base used a T27 torx wrench to get screws loose. worked on one wont work on the other one. I got a feeling the head is stripped. If I try to tighten the screw the wrench seems to get a good bite on it but to loosen nada. Does anyone have any ideas how I can get that other screw out? Should I try to drill it out? Should I just take it to the garage and let them deal with it?
