Old 04-02-2013, 01:50 AM   #1
particlewave
As long as you're not exceeding the stock bulb wattage, power should not be an issue. The HIDs and LEDs should actually be more efficient, assuming that you stayed below 55watts on the HIDs.
Could be a ballast going out...but I doubt it. They usually just stop working. I would check each ballast with an ammeter and calculate wattage to make sure they're not exceeding stock.
The switch itself may be a more likely culprit.
