Old 04-01-2013, 03:27 PM   #1
Topless
Track rat
Topless's Avatar
If there is oil in the coolant it will rise to the top (oil floats) and look like brown goo. Probably not what you are seeing. Maybe just a failed ign switch allowing the starter to turn but no spark. Are you sure you have gas?
A failed crank position sensor will also cause this symptom.
