Old 03-27-2013, 05:50 AM   #1
Meir
1999 base
Meir's Avatar
Originally Posted by Fhelfrich View Post
That certainly seems plausible.
Is replacing the bulb a major project? Is it accessible or do I need to remove major parts?
first, removing the cluster and replacing the bulb, is not a complicated task.
however, before you go and take the cluster apart, confirm this is your problem.
turn the ignition key on, and look at your cluster (without starting the engine).
in that point all the lights in the cluster should turn on (including cruise control).
if the Cruise control is on, that's not your problem.
just in case you are not familiar with the cruise control light location:
996 dash lights
#3 - green light
