Old 03-26-2013, 05:08 PM   #14
McDuff
Mcduff - 99 Boxter
Thanks guys, appreciate the input. I had it serviced just before storage, even changed tranny fluid. Had trickle charger on it all winter, and did the steel wool in the tail pipe, pumped tires, even put a pan with charcoal in passenger area to absorb moisture! All ideas that came from this web site.
I will do as you suggest, turn the key and let it warm up. I just saw the comments regarding the oil being totally trained to the lower pan, and dry pistons, and did not want to launch the motor before I really got to drive it. Sounds like maybe overkill.
It's a 99 as I said, with 30,00 miles, gray on gray, and I am excited and get going. We live in cold weather also (Michigan), so we get about 5 months use, and it is about to start.
Thanks again for your input!
McDuff
McDuff is offline   Reply With Quote
