Old 03-26-2013, 03:03 PM   #3
fitment
Originally Posted by Nimbus117 View Post
Have you checked for vacuum leaks around the throttle body?
Any issues with the throttle pedal itself? check the hinge at the bottom hasn't broken.
Any other symptoms, loss of power etc. Any error codes?
i have no power loss. Power is still great.
There are no error codes. (with Delphi)
with vacuum problem the throttle can hang in the same rpm, but can it also go higher in rpm? from 4000rpm to 6500rpm.
When it comes beneath 2000rpm/2500rpm it fall's down normally.
fitment is offline   Reply With Quote
