Old 03-26-2013, 03:12 AM   #3
KevinH1990
KevinH1990's Avatar
The only reference I could find was a 2003 996 owner's manual. It said the pressure should be approximately 3.5 bar at 5000 rpm with a fully warmed up engine. It seems like my 2.7 runs at about that level.
For the volt meter the normal range is 12-16 volts. If it is below 12 with the engine running, you should "have the charging system checked at an authorized Porsche dealer."
