Old 03-10-2013, 12:52 PM   #3
Jager
Jager's Avatar
I am IMS STUCK! After removing the IMS bearing in one piece. I am not sure what do about this….
My engine is locked at TDC (at BOTH ends of crankshaft and camshafts). Chain tensioners are OUT. I removed the IMS bearing - NO PROBLEM!!
However, my IMS bolts are lining up in the crankshaft HOLES…NOT on the steel part of the crank flange. It is supposed to be a friction fit on the crank flange and MUST NOT be tightened down into the holes. HOW DO I SOLVE THIS? Will is re-seat itself when I re-install the Chain Tensioners?
I have the chain tensioners out at the moment….I am hesitant to turn the crank WITHOUT CHAIN TENSION.
So, the question is - and I have researched my tail off but cannot find an answer:
HOW do I make sure the Crankshaft holes are NOT UNDER the IMS BOLTS? How do I move them to safe ground?
Did you lock your crank at TDC?
Are you trying to stabilize the IMS gear with set screws? This is not required as long as you are locked at TDC. But if you are using set screws to help stabilize the IMS do not over-tighten.
Jäger
300K Mile Club
