Old 03-08-2013, 02:49 PM   #18
BruceH
BruceH's Avatar
Originally Posted by Steve03986 View Post
I did it last summer, but recall it involved cutting the + and - wires from the parking light, splicing-in extensions to each of those wires, and then splicing into the + and - from the brake lights. There is not much room to work with inside each light fixture. Hope this helps.
So I tapped into the brake leads and then tapped into the outside LED/parking LED. It works, but not all the time. Sometimes, the first press of the brakes results in only the original brake LED's coming on. The second press results in both the inside and outside LED' illuminating. Does yours do this?
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
