Old 03-02-2013, 09:36 PM   #5
AKnowles
AKnowles's Avatar
The speakers have a mounting depth of 2 13/16" so they should fit, but just in case I also bought a 1/2" mounting ring. I haven't installed them yet. As for the amp, I bought a Helix Blue 5. It is mounted on the floor of the frunk. I pulled the original amp.
You have to use a template of some sort since the stock hole is made to fit the stock woofer whcih includes an enclosure. Either that, or you'll have to seal the rest of the door. I thought about that too, but just decided to use the template. Oh, I forgot, using the template does not require chopping up the door since you are just sealing the hole already there to fit the enclosure.
