Old 03-02-2013, 10:44 AM   #12
Perfectlap
Perfectlap's Avatar
Originally Posted by AndrewG View Post
You can reroute the wires so one of the sets of LEDs feeds the rear running lights and the other set of LEDs feeds the brake. I have my DEPO lights set that the inside set of LEDs are always on when my lights are on and the outside set for brakes. It takes a little patience to feed the wire plug through the light assembly but worth it.
I peeled back the grommet, moved the other wires out of the way and still could not get the plug to fit in that little space. Then being impatient I got out the drill gun.
don't do this without moving all the wires out of the way. But with two 1/8 holes it cleared enough space.
I'll miss that parking light though. I use that all the time when I leave the car parked in a dimly lit parking lot. makes the curious think someone's in the car.
EDIT:
You don't lose the parking light after all. But strangely after i start the car and turn on the lights the rear lights will only turn on if i turn the lights off and then turn them back on again. Also, its a good idea to have some touch up paint handy. I had some chipping under the old tail lights and Depo lights have a slightly smaller footprint which revealed the paint chip.
BORN: March 2000 - FINLAND
