Old 03-01-2013, 07:27 PM   #2
thom4782
thom4782's Avatar
Thanks for the suggestions so far.
The noise isn't radio related. It's there whether or not the radio is on.
I'll double whether it comes from one of the condensers. I might be surprised. The sound however seems like it coming from the area under the expansion value / pollen filter. I suppose it could be the evaporator.
Two follow-on questions if the sound is coming from the condenser or the evaporator, hyw would one of these components make a whining sound? Why would it change with engine speed? I could guess the answer to the second question -- the refrigerant pressure and flow rate increases as the compressor speed increases. If the noise is flow related, the its pitch could be higher with greater flow rates.
