Old 02-27-2013, 09:20 PM   #1
nieuwhzn
nieuwhzn's Avatar
The oil change is pretty easy to do IF the oil plug is not over-torqued. I had serious problems getting the thing out the first time I did an oil change.
Also make sure that you have the special tool to remove the plastic oil filter housing, it can break easily. Use a torque wrench to reinstall the oil plug (with a fresh crush ring) and the oil filter.
nieuwhzn is offline   Reply With Quote
