Old 02-17-2013, 10:48 AM   #1
berty987
I removed the complete arm when I did mine , its easier to fit the dampers on a bench to the bracket and then install the complete arm. There are a few options for the damper rate also , personally id replace both dampers at the same time. I used an engine / gearbox jack to support the transmission while I removed the mounts , just makes life easier.
berty987 is offline   Reply With Quote
