Old 02-13-2013, 10:54 AM   #21
tcallas
While you're here. Do you factor in engine sound at all when you determine if an oil is better or worse for the m96? Some people take comfort in a quieter engine.
Great question, I would have to say yes. Actually, I will back pedal some on this one, I was thinking about warm running conditions/noise on the M96-M97 engine, but the start-up noise does seem slightly better with the 5w-40 weight lubricants. The greatest growing concern of mine right now is the M96-M97 IMS chain tensioner. If it were mine, I would replace that tensioner every 40k miles. Jake has seen catastrophic engine damage occur when the IMS chain tensioner has worn-out and left loose for too long. Listen for ratting noises on cold engine start-up, this can be indicative of a worn out IMS chain tensioner. It’s now on my list of preventive maintenance items, not to be taken lightly.
Good luck,
Tony Callas
Callas Rennsport
tcallas is offline   Reply With Quote
