Thread: H&R vs row m030
Old 02-08-2013, 08:03 PM   #2
Topless
Track rat
Topless's Avatar
Curious to know what your thoughts are regarding the long term effects of using stiffer aftermarket lower springs with the oem struts. Have you seen cases of suspension "sag", or even shock blowout over time ?
Clearly the best setup is to have springs that are matched to strut dampening or vice versa. I have not noticed spring sag or obviously blown out struts when running lowering springs but if the car is 10 yrs old, the stock struts are pretty far gone already and probably won't play well with stiffer springs. My impression from student cars running HR springs was simply "stock probably handled better." YMMV
