Old 02-06-2013, 08:16 PM   #1
boxster6354
boxster6354's Avatar
Yes it will be quite obvious, the MOMO knob is round and the stick of the box is rectangular so you will just round off the four corners a bit at a time till it fits.
Took me maybe 10-15 minutes with a dremel, make sure to wear gloves as it will get hot, also I did not do this while in the car, I had removed it as I was installing a short shift kit at the same time.
There is a write up on Pelican Parts.
Pelican Technical Article: Boxster Gear Shift Knob Replacement and Upgrade - 986 / 987
boxster6354 is offline   Reply With Quote
