Old 01-31-2013, 04:01 PM   #2
LAP1DOUG
LAP1DOUG's Avatar
Originally Posted by Spinnaker View Post
PLASTIC RIVET
G99950749940 - Genuine Porsche
Description
Known as: expansion rivet
Also, pop rivets work fine if you have a rivet gun. As I recall, I used 3/16" rivets. Use the cheap aluminum nail kind so they are easy to drill back out if you ever have to take it off again.
When bolting putting everything back together, just check the alignment carefully as you go to make sure it goes all the way down without sticking, or you'll get to o it again (or be one of those running around with a large gap to the body).
Good luck.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
