Old 01-24-2013, 08:45 AM   #7
jaykay
jaykay's Avatar
Originally Posted by com3dorm3 View Post
Done all that.
Radiators: Looked like someone was using it to mow the lawn.
I cut the line to drain the system and install the PS cooler, but I did not see any plug or drain valve.
Thanks for the planet9 referral.
I plan on installing a full sweep oil pressure/temp gauge... just because...
As far as oil starvation, I'm hoping the oil sump baffle will do the trick initially, as suggested by some of the members here.
In my case, we're talking about a driver with less than 10 track days of experience and non-sticky tires for now.
but then,
Would you elaborate on the issues and root cause?
Oil temperature!
986 00S
