Old 01-24-2013, 06:51 AM   #3
MConte05
Originally Posted by fatmike View Post
Just so we're clear. It snows in Germany. The car is tested in Sweden.
Put some winter tires on it, and the car far exceeds expectations in the white stuff.
Damn straight it does.
Just remember that if it starts to get away from you, more throttle WILL fix the problem. Stepping on the brakes will not.
For those of you terrified of driving in the snow, next time it gets wet or snowy outside, go to the local parking lot and play around. Don't just do donuts. But try sliding around, maintain a slide, use engine braking to slow you down, learn how to threshold brake. Not only will you be giggling with a big grin on your face, you'll be learning valuable car control!
MConte05 is offline   Reply With Quote
