When I installed mine, I did not latch the front until the top frame was completely installed and pushed back at the corners so the latch would clear the wind deflector. Did you bolt the top frame down with the front latch closed? If so, I would unbolt the frame, unlatch the front, bolt down the frame while making sure the frame is pushed back far enough to allow the open latch to clear the wind deflector, then attach the ball ends w/pushrods. I would then operate the top to see how it opens and closes. The latch is designed to pull the top taut when you close it.
