Old 01-20-2013, 07:50 AM   #10
Homeboy981
Homeboy981
Homeboy981's Avatar
@Meir,
Someone should know how much these will hold from DRY (or doing an IMS change).
Didn't you drain a bunch of oil in the IMS replacement process? Didn't approximately a quart (or more) come out after removal of the IMS? And this is your first time to check since then...
You should be O.K., it looked like there was a lot on the floor of your garage!
I will catch it when I do mine and let you know!
Thanks!
According to the owners manual, the amount of oil needed for an oil change is 8.75 liter, including oil filter.
So in my last oil change I started with 8 liters, and kept adding up.
Also curios to know what is the amount of oil that goes into a "dry" engine (after a rebuild for example)
Thanks in advance.
Meir.
