Old 01-19-2013, 08:43 PM   #8
Meir
1999 base
Meir's Avatar
Originally Posted by thom4782 View Post
I'd provide a reference if I could remember where I read the following. The timer uses a 1 minute countdown when the engine is cold or after 10 minutes have passed after a warm engine is shut off. If the engine is warm and is less than 10 minutes after it's been shut off, the timer sets a much longer count down period to allow the oil to drain into the sump. In my car, the 'long' count down starts at 60 minutes if I turn the ignition back on right after shut down.
that's exactly what i did.
as soon as i got home from work, i turned the ignition off, and then back on.
the temp was showing at 180, and the timer started at 40 seconds (more or less).
ill have a look at it again just to make sure.
thanks guys.
