Old 01-19-2013, 02:43 PM   #1
Neil_Broadhurst
Hello Essex ! I'm originally from Surrey but now living in North Carolina, Hope you've not got too much snow !
This problem sounds a lot like one of my many problems that I had last year when I bought my 98. Mine would take a few turns to start and sometimes kick out smoke and was generally very rough and idle and revs were drifting up and down.
I found that I had a cracked Oil Filler Tube and a completely stuffed AOS. This resulted in loss of vacuum and a ton of oil getting into the inlet manifolds.
A fairly quick check would be to remove your Throttle body and see if you have oil in the inlet manifolds. Mine was coated in about a millimeter of fresh oil !
The Oil filler Tube is a sod to replace but the AOS isn't too bad.
Cheers .. Neil.
Neil_Broadhurst is offline   Reply With Quote
