Old 01-16-2013, 06:32 PM   #1
Bryan topping
I have a 2001 base coming up on 1 year of ownership.
Done so far:
Climate control LCD
Serp belt
Air cleaner & cabin filter & fuel filter
Oddments tray lid upgrade/repair
Alarm horn
Convertible top
Fuel door lock
2 new key fobs
Front control arms & diagonal arms
Front strut mounts & strut bearings & bump stops
Battery
Starter
Rear tires
2 oil changes with filter
Trans fluid change
Front sway bar drop links
Plugs & tubes
One radiator fan
AOS
Misc trim items
Activate the OBC with dash switches
On the horizon:
Coolant pump/thermostat/hoses with cooling system flush & refill
Brakes
Short shift kit
Total so far in parts is a little over 4K
Bryan topping is offline   Reply With Quote
