Hey guys - I am looking to do this as well. What's the best way to access the ball joint area with the car on the ground? I turned the wheel all the way, but it's a tight fit with the wheel on. I can squeeze my hand in to touch the ball joint, but it's tight to do accurate puncture of the joint and put wd40 in.
Also, should I just use the straw with the WD40 can and cut a hole, or is it worth it to try and use a grease gun or something like that?
