If you are not afraid of a little mechanical wor, several of those are things you can do with a little reading in the DIY section of this forum. For example oil change and plugs you can do for about $125 in parts. Brakes you can do for about $650 if you replace rotors and all. Less than $200 just for pads. A set of Hankook V12's will run you between $450 and $650 depending on size and they are great tires. As I see it, you are looking to find a good independent porsche mechanic to do the clutch and IMS and a good top shop to replace the back window and let your insurance company replace the windshield and you should be able to do the rest. I think you can get out for about half your estimate.
