Old 01-15-2013, 10:33 AM   #1
ajclarkey
Boxster cold start problem - lots already tried
Hello, I'm a fairly new Porsche Boxster owner having purchased one in August 2012 and having problems now which has cost me over £1000 in the last few weeks and still not fixed. looking for some advice please, I'd be really grateful!!
I have a start up issue has been going on for a month and been in the garage 3 times and still can't fix the problem.
Its a 2000 registration 2.7 litre Boxster with 49000 miles.
Everything was running fine until I took it into have a service and MOT by a non specialist garage.
He changed the oil filter and air filter and changed oil with Mobil1 5/40 fully synth (although when I picked it up I noticed he had filled it over the max mark, not sure if this makes much difference, he stated it was 8 litres).
The next day it took around 20-30 seconds to start the car and really struggled to ignite but was turning over fine. It wouldn't start unless you pushed on the gas pedal. When it does start there are huge white smoke clouds from the exhaust for about 30 seconds which smells strongly of fuel. After that initial drive it then starts fine first time for the rest of the day. When left overnight the problem returned on the first start up.
Took it back to mechanic and he couldn't work out the problem was (no check engine light) and changed the fuel filter. This made no difference.
Took the car to a specialist (by now the check engine light had come on) who told me it was the pre cat Lambda / 02 sensors had both seized and need replacing and so he did.
Got car back, problem exactly the same and check engine light returned the next day. Took it back and specialist, now state it's the Mass Air Flow filter and so changed that, before picking up the car he told me it was still a little slow and so changed the spark plugs also.
Got car back problem exactly the same - first thing in morning doesn't want to fire up and eventually have to press the gas pedal to get it going.
From research I thought initially it might be the AOS but doing the oil cap test when engine is running proves that it probably isn't as the cap comes off without any vacuum.
As these repairs have cost me over £1000 now and problem still remains I'm losing all patience and trust with the garage, what do you suspect? I've put a video on Youtube Boxster 986 cold start problem - YouTube you can hear when it starts struggling I press on the gas which fires it up but if I don't do that it will continue to struggle for 30-40 seconds or longer before starting!
ajclarkey is offline   Reply With Quote
