					Originally Posted by rcbox2k1  I think what you used is better since it states specifically it is compatible with the CDR 220.  During the install, did you remove the CD holder panel or do you have a compartment?  If so, how did you remove the compartment? |
Yes, I removed the CD holder and got a bin from Pelican. I got the keys from Suncoast. The CD holder comes out easily. Once you take the side panels off, you will see. I Dremeled a slot in the upper right corner of the shelf to slide the iPod chord through.
Here is the info for the shelf:
996-552-253-01-01C-OEM          $46.75         1          $46.75
   Storage Shelf, Upper (Satin Black), Boxster 986 (1997-2004), Brand:
   Genuine PORSCHE
