Old 01-05-2013, 11:06 AM   #8
Jager
Jager's Avatar
Originally Posted by Kenny Boxster View Post
Not bad, Mr. Jager. Is the success rate very high with the plunger? Looks nifty.
Success will depend on the dent depth… it can’t be too deep. Sometimes the dent can be removed and there are no signs it was there, other times there is a little distortion but it looks allot better than the dent (I put it at 50/50). If you are a perfectionist I recommend taking it to a pro.
If you have never used a system like this practice on appliances or older, less cared for, automobile before using it on your pride-and-joy.
You need to make sure you are using this system on original paint. Also there can be no paint damage in the dent (chip, scratch) otherwise it could pull-off some of the paint.
For a small dent use a small amount of glue and move the support pads as close to the plunger as possible, this will reduce the possibility of pulling the dent up too far and creating a bump.
Jäger
300K Mile Club
