Old 01-03-2013, 03:08 PM   #10
Eric523
Boxster Abuser
Eric523's Avatar
another question - with the electric power steering - are you running a mercedes or mr2 pump, do you run a cooler on the ps fluid (to remove heat introduced by the pump) and have you experienced any lag in response from the pump (apparently later model mr2 pumps have internal controls that slow the motor when not in use but can be a little slow to get back to speed with rapid steering input).
sorry to pester!
not pestering at all, wouldn't hang around here if I wasn't willing to share and answer(or ask) questions.
I'm running the GT3 cup car pump. Same as a Vauxhall and maybe a few other cars but I'm not sure of all the applications. I had heard of using the MR2 pump before but I don't believe this is the same. You can find these GT3 pumps on Ebay usually for around $500-$600.
This pump does have the ability to back itself off when running down the straights so it doesn't build up excessive heat and also reduces the draw on the motor/alternator for voltage requirements. I didn't perform the wiring on it so I'm not exactly sure how that all works but it is the same in my car as a factory cup car or RSR would be. No coolers necessary.
It's hard to tell any difference between the electric and belt driven pumps when on track. If anything, I think the electric pump makes the car easier to steer. I increased the size of my front wheels/tires, increased the grip by using a lower compound, increased front down force with aero, and widened the front track and it still seems like it takes a little less effort than the car used to with the belt driven pump.
Very cool system but I wouldn't do it unless I was tracking a lot. The later 987 models can benefit from improved reliability because of all the failures they have on track from overheating stock systems. We do put coolers on the 2005-2008 model 987 cars with stock pumps that see track use, along with under drive crankshaft pulleys for that reason.
4.0L Dry Sump Boxster GT race car - HRG #23
2005 Cayenne S - DD
Eric523 is offline   Reply With Quote
