Old 01-01-2013, 11:20 AM   #4
Gilles
more room..?
in order to have more room to access the damage bolt you may want to consider lowering the engine a bit.
While replacing the front engine mount I noticed that you can lower the engine at least one inch, perhaps a little more.
With the extra room you may be able to access the stripped bolt with a Dremel tool to cut the head of the bolt off (or make a slot on it).... just a suggestion
Good luck
