Old 12-20-2012, 01:05 PM   #1
seventythree
Hitting the axle end with a hammer will potentially damage the wheel bearing, and that's when the real fun begins.
Remove the brake rotor (real easy), and use a large gear puller to push the stub-axle out of the hub.
Either way, squirting some PB Blaster in between the splines with break things loose much faster.
seventythree is offline   Reply With Quote
