Old 12-19-2012, 08:48 PM   #1
The Radium King
The Radium King's Avatar
Separate the header from the mid pipe.
Seperate the mid pipe from the muffler and undo the bracket that holds it.
You won't be able to remove the mid pipe but you can drop it a couple of inches and that should give you enough room to manipulate the axle.
Buy a brass plumbing fitting from a hardware store.
Remove the big axle nut on the end of your axle where it passes through the bearing.
Hold the brass fitting on the end of the axle and hammer it; the brass will marr instead of the steel axle and it should come out.
Use this approach and there's no need to disassemble your suspension.
