Old 12-15-2012, 06:04 PM   #19
Little "t"
Little "t"'s Avatar
You just wait Helfrich...
[*]Tires: 5 sets x $800 per set = $4,000 (5th set is brand new and will be used into early 2013)
You just wait Helfrich, soon you'll be burning threw a set of tires in a weekend, then you'll be spending $14,970 on rubber alone!
I used to be able to get 20 heat cycles out of a set, then 16 heat cycles, and now 10 heat cycles are about the max before the car starts pushing... Last time I was at Willow with 12 heat cycle tires, the car was pushing so badly threw the omega, I had to rotate the steering wheel over 180 degrees in order to make the apex at four!
But hey, as Marty told me, you could always go slower!
When I can, I walk...
Little "t" is offline   Reply With Quote
