Old 12-11-2012, 11:42 AM   #1
Kroggers
When you say slotting the brackets, do you mean making the mounting holes in the radiator frame oblong so you can push it further forward? I looked at this, and I do not think there is enough material to permit you lengthening the holes by 1/2" - will look again tomorrow.
My initial idea is to just try to twist the radiator so the outer most part which the wheel is contacting is further forward - this will only require the bracket to be bent slightly and one of the mounting holes under the car to be made larger.
I should have some time to play in the morning and will post back with some updates for further discussion...
What size wheel/tire are you running up front? I have gone to a 18x10 wheel with a MPSC 265/35 - my early Christmas present (as you have seen )
Kroggers...
"Trying to drive a Boxster S for team CoolCava Racing!"
www.coolcavaracing.com | www.paulkrogdahl.com
Kroggers is offline   Reply With Quote
