Old 12-03-2012, 11:00 AM   #1
Heiko
Heiko's Avatar
If the pump goes dry when you put pressure on the steering rack by turning it could make strange noises. If a tire rubbed in the wheel well I would think you would feel it.... I would check everything that moves like drive shafts (check for play), jack the car and give the wheel a firm tug side to side and top to bottom to see if there is noticable play or not. I've also seen the splash shields behind the rotors (if they are too close to the rotor) scrape when turning which causes that type of noise (those splash shields are thin metal and bend easily so take a look)
Heiko
Previously owned:
