Old 11-13-2012, 09:04 AM   #17
Gorthaur
2000 Boxster S
Originally Posted by Eric G View Post
Will be interested in seeing if this helps. I know Porsche has a "safe drive mode" where the engine will drop cylinders when the CPU detects an engine problem and gives you just enough engine to return home. The symptoms you are describing are identical to the conditions my 928 S4 would go through. No codes were thrown, but if I remember correctly it ended up being a coil related issue. On the 928 you would go from 8 cylinders to 6... I have not found if the Boxster has the same function going from 6 cylinders to 4?
At 1500 RPM I'm not so sure I would be able to go anywhere, even a small ramp would be too much for the poor power available. There's clearly something wrong!
Gorthaur is offline   Reply With Quote
