Old 11-05-2012, 01:48 AM   #12
ccstud17
ccstud17's Avatar
Originally Posted by barkinfool View Post
TRK -
It is true that you won't get the time back, but when you die, you will achieve total consciousness.
So you have that going for you, which is nice...
Thanks, your post was very helpful!
YES CADDY SHACK!!!
Living in Portland, I have not had any issues with bad rain getting in the engine, First rain after de snorking, i drove on the high way pulled over and felt my intake, the grill was dry! maybe luck or the aerodynamics had the heavier water droplets moving faster than the lighter air, so at higher speeds the water does not alter its path. Just like driving with the top down while it is raining, if you go 95+ MPH top down you will stay dry! (Mythbusters did this in a boxster)
ccstud17 is offline   Reply With Quote
