Old 10-30-2012, 06:17 AM   #1
Homeboy981
Homeboy981
Homeboy981's Avatar
Turning One Way Easier Than The Other?
I installed a cold air intake last night and took it out for a road test.
Doing some low speed turns, like switchbacks-back-to-back lefties and rights in second and third, I observed the rear end stepping further out when turning right than it does turning left…same speed same road surface. Tire pressure was the same in both (29f/35r).
I (no passenger) went back the other way, and duplicated results and the same thing happened going the other way. So I can rule out the road surface. But all things being equal, what would cause that? I have physically checked the links, suspension, ties, etc. nothing obvious.
Where/what should I check from here?
