Old 10-18-2012, 12:50 PM   #20
shadrach74
thanks for the update Blair.
a little bit disappointment that the numbers are so much apart then what is posted on the Pedro website. (+30HP)
with that said, he dose recommend a use of high performance exhaust system for best results.
i think ill give it a try anyway.
the plan as i mentioned earlier, is to go catless.
i think i will run a dyno as it is today (TS bypass pipe and de shnork)
and once again after installing:
the full thechnopwoer2 kit
UDP
headers
modified exhaust.
if ill get +20, its worth it.
The way I read this is he's got 26+WHP from stock (which is well over 30BHP from the stock 250BHP). The Fabspeed might help a bit by deleting the secondary cats, but I doubt the muffler has any bearing on performance. This actually appears to be a worthwhile mod. Not cheap, but if $1500 gets close to a 26WHP gain without altering drivability or emissions...then it's not horrible either. A 986 with 280ish on tap is going to feel very lively indeed. That about 10lbs per hp as opposed to over 11lbs per hp for stock.
shadrach74 is offline   Reply With Quote
