thanks for the update Blair.
a little bit disappointment that the numbers are so much apart then what is posted on the Pedro website. (+30HP)
with that said, he dose recommend a use of high performance exhaust system for best results.
i think ill give it a try anyway.
the plan as i mentioned earlier, is to go catless.
i think i will run a dyno as it is today (TS bypass pipe and de shnork)
and once again after installing:
the full thechnopwoer2 kit
UDP
headers
modified exhaust.
if ill get +20, its worth it.
