Old 09-30-2012, 10:01 AM   #7
jb92563
jb92563's Avatar
Originally Posted by mikehkang View Post
You won't have trouble finding it.
BTW, will you be bleeding the clutch?
Both the brake system and the clutch share same fluid.
The clutch bleeder valve not easy to get to but you still have left over brake fluid.
Hmmmmm, did not know that about the clutch sharing the brake fluid, I'll have to look for the clutch bleed screw, Just one???
I found the Brake pad specs. My Fronts are 1/4"(6.4mm) and Rears 3/8"(9.5mm) so 53% and 90% respectively.
