Old 09-21-2012, 08:00 PM   #1
Jittsl
SPB racer
Keep in mind that the clutch pulls from a completely different nozzle on the fluid reservoir so it will have no effect on brake performance. It is also under negligible temperature and pressure compared to the brake system. If your clutch is working perfectly then there is probably no reason to bleed the clutch until you need to replace the slave cylinder.
Jittsl is offline   Reply With Quote
