Thread: air compressor
Old 09-14-2012, 08:01 AM   #17
opus69
I have a small compressor I used for brads and finishing nails so I decided to try a 1/2 impact wrench with it and it worked fine. It is only 6 gallons, but it will develop 150 psi. No problems at all for removing lug nuts and such. It may cycle more frequently, but unless you are in a shop and using it all day I found it to be adequate. If the original intent had been to use air wrenches I would have gotten a larger capacity system but since I already had this smaller unit, I tried it and it worked fine.
opus69 is offline   Reply With Quote
