Old 09-10-2012, 09:28 PM   #6
Dave928
Location: Seattle - It's not Hell, but you can see it from here!
Just so I understand you correctly, you're running both 200 cell pre-cats and 200 cell secondary cats ?
yes. here's the link...
Porsche Boxster 986 NHP Performance Exhaust 2.7L/3.2L
Originally Posted by ohhh my View Post
isn't idling the car for long periods of time really bad?
as long as the water pump and cooling fans are working, isn't going to hurt anything.
was brainstorming with a friend earlier, it sounds like an exhaust leak at the manifold gaskets. when at idle it would draw air in, making the S1 O2 sensor think the engine is running lean, so the ECU adds fuel, making it run rich. then at cruise, the exhaust blows out thru the leak, not affecting idle fuel trims. EXCEPT, it's both sides.
so either there's a header leak on BOTH sides (seems unlikely) or the problem is upstream of the engine... ECU, MAF, or throttle body. the question is why one of those would crap out from just changing the exhaust...
dave
2001 Porsche Boxster S
1988 Porsche 928 S4
Dave928 is offline   Reply With Quote
