Old 09-06-2012, 04:44 AM   #1
matthew
thanks i plan on switching the whole bumper to a 996 turbo style as well as the headlights... right now i have the boxtser stock headlights with a fiberglass aftermarket 996 turbo bumper and would rather have a OEM 996 turbo bumper on the car.... good to0 know most of the OEM headlights are plug and play
Originally Posted by Skrapmot View Post
The 2001 and later Mk2 996 headlights are not the same as a Boxster or earlier 996s , and have a different bumper line than previous models. Earlier 986s and 996s are the same except i discovered the hard way that the 996 has a shinier cross pattern inside the light housing where as the 986 Boxster has straight lines and a less reflective surface inside.
The litronics are just plug in and play but if you want the touted self leveling feature there is some extra wiring and a module required that sells for a couple hundred bucks.
matthew is offline   Reply With Quote
